Gear S3 randomly turns off and wont turn back on unless on charger first
(Topic created on: 1/8/18 10:12 PM)
userKU5nOAfdnl
Gear and Gear Fit
I updated my Gear S3 Frontier this morning and ever since, along with the battery overheating issue on the charger like a lot of other folks, now the watch turns off randomly after 5 or 10 minutes, and won't turn on again unless I "reset" it by placing it on the charger until the screen comes up showing it's charging. I haven't actually seen it turn off yet so not sure if there is a message or notification beforehand. Any others have these issues or any ideas how to fix them? Thanks...
SamsungJace
Gear and Gear Fit
If a factory reset hasn't helped the symptom you'll likely need a service repair on the watch. If you would send me a private message here with your full model code and Serial number I can look into what your options are.
Dubay
Gear and Gear Fit
I had the same problem. Completed the update to the update with no success in solving the randomly turning off and could only restart with the Gesr S3 on its charger. I contacted Samsung Support via phone. They had me return the watch to them for repair. It came back with the older o/s Tizen 2.3.2.4. And a new battery. The S3 is working fine now and I'm being notified to update the o/s again. I'm gun shy and afraid to do it again. My Gear S3 was under warranty and repair and shipping was free.
Dubay
Gear and Gear Fit
userwm0x8jAbU9
Gear and Gear Fit
Yup same here .sooo frustrating, looking for a fix also .Please help
userhYLFTIEW8q
Gear and Gear Fit
Same problem.  Recently started shutting off - most annoying especially when I’m in the middle of a run and I lose my workout data.
userDBvsAJEuDh
Gear and Gear Fit
No answer from Samsung for 5 months?? Please tweet @SamsungMobile, post on Google, Facebook, LinkedIn, etc, that might motivate them
user33DXAR6r2d
Gear and Gear Fit
Sam here. So frustarting. Anybody got a direct number to call?
Thanks
HalloweenMike
Gear and Gear Fit
I've been having the same issue. The watch is a year and a half old. The battery says it has anywhere from 70% to 86% and it will just shut off. I can turn it back on most of the time with the button, but it usually shuts off right away. I put it in the charger for a bit and it can then be turned on after a bit. It just shut off and when I put it in the charger it says 80%. I can't get it to stay on without it being in the charger.
userVobI998DAa
Gear and Gear Fit
I had the same issue with the watch being same age; rep at ATT suggested paying for new battery.  I had it replaced costs $80 but now watch works as it should.  I can go all day and use 30% if I actually am checking things on watch.
useraewvBcABwS
Cosmic Ray
Gear and Gear Fit
Same problem. Samsung as a company does not care.
