Highlighted
Cosmic Ray
Gear Sport - Shorter Watch Strap
JUMP TO SOLUTION
I've just got the new black Gear Sport - my first smart watch.  I liked it partly because it's a bit smaller, but the watch strap is long for my wrist.  The strap is around 8" if I measured it correctly.  Does anyone have recommendations for shorter straps?  I'd really like the same style as the stock strap (textured,charcoal, silicon), but shorter.  I guess that's asking too much...
1 SOLUTION
Highlighted
Re: Gear Sport - Shorter Watch Strap
JUMP TO SOLUTION
mine came with an extra short strap in the box, have another look
3 REPLIES 3
Highlighted
JUMP TO SOLUTION
Highlighted
Cosmic Ray
JUMP TO SOLUTION
Thank you so much!  I thought that little pouch was just padding - I had almost thrown the box out.
The short strap is perfect.
Highlighted
JUMP TO SOLUTION
I nearly did the same mistake! The shorter is perfect for me.  Strap Studio is going to have around 20 more straps to choice from to Gear Sports.
