Highlighted
Gear fit 2 Pro Overheating
Dear,
My gearfit 2 pro is overheating. It charges fine to 100%, then when I wear it it gets extremely hot and the battery drains super fast. I tried updating everything via the gear app but no success.
Any suggestion on what to do next?
SM R365
thanks in advance
5 REPLIES 5
Highlighted
Re: Gear fit 2 Pro Overheating
Thank you for reaching out. I would recommend a service repair. Can I please have your full model number and serial number/IMEI in a private message: http://bit.ly/2JH2rq2
Highlighted
Hi,
I sent a private message but got no reply yet.
did you receive it?
thanks
Frank
Highlighted
@usereugqP3xOIE Hello Frank! Unfortunately, we have not received your private message. Will you please try sending it again? http://bit.ly/2XERsky
Highlighted
Adam,   What is a service repair? Will I have to send my watch or can I do that myself? Information here: Serial number S/N <hidden> (small on back on watch) Software version R365XXU2CRC7  Serial number <hidden>  Is this the information you need? Best regards, Frank
Highlighted
No worries. Private messages have to be sent through the web browser and not through the Members app. You are welcome to find a local repair center for the watch. This link will give you options for walk-in and mail-in: https://www.samsung.com/us/support/service/
