Highlighted
Gear fit 2 pro overheating and no power after
My Gear fit 2 pro said it was overheating and shut off. It will not turn back on. I have tried charging it as well thinking the battery had drained but that is not the case. I cannot turn it back on. Any suggestions or is it a goner?
1 REPLY 1
Highlighted
Re: Gear fit 2 pro overheating and no power after
Hey there!
I would be happy to look into your concerns.
Can you please send me a private message with the below information here at this link: http://bit.ly/2GH8URL
Model code:
Serial Number:
