Gear fit 2 pro stopped tracking steps and HR
(Topic created: 01-15-2018 08:58 PM)
kitza
Gear and Gear Fit
I bough gear fit 2 pro from Samsung Shop Thailand since November. It's work properly until yesterday. While I running with gear fit, GPS not work so I reset gear. After reset It can not track step and HR but GPS still working. It has one more problem that it can't use motion to wake screen.
Model: SM-R365
Software Version: R365XXU2BQJ4
userZ9MRcyc4aK
Gear and Gear Fit
Hi, I had the same problem, but the solution is very simple.
Just turn on the GPS for a while or start the "walk" training with the GPS enabled (only a few steps), then turn off the GPS (training and GPS off to save the battery).
After that everything started to work correctly. Cheers!.
SamsungCourt
Nebula
Gear and Gear Fit
Hey Community! Anyone else seeing this problem? Anyone have a workaround? Let us know!  🙂
userM11MX3d7EY
Gear and Gear Fit
I am facing the same issue.. no steps count , no HR, no auto wake ..
tried reset, restart etc. No success
userMFATqFgCJS
Gear and Gear Fit
Having the exact same problem. Can't even tell if it's a hardware or software issue. It stopped working out of nowhere.
mvirkus6
Gear and Gear Fit
Didnt even receive my promo when purchased edges7
userdiaTRt9iBT
Gear and Gear Fit
I have had the same problem for 4 days now
userki0SEqLqjY
Gear and Gear Fit
I tried everything too. Now mine keeps rebooting every two minutes.  Nothing seems to be working with either problem
userq6qLQluxqI
Gear and Gear Fit
I also have this problem since yesterday (6 March 2018).  My Gear Fit 2 Pro just stopped tracking my steps and heart rate.  Today, in exercise class, the Auto HR monitor kicked back in for a while and then stopped again, but only a fraction of the steps are being recorded.
userq6qLQluxqI
Gear and Gear Fit
I also am having this problem.  Yesterday, my Gear Fit 2 Pro just stopped tracking heart rate automatically, and only records a few steps occasionally.
userlnIzymyC7Q
Gear and Gear Fit
My Gear Fit 2 Pro also have same problem.
HR can not measure, wake up gesture can not work and counting step too.
I had restart my gear but still don't work properly.
Please solustion?
Best Regards,
Candra Zhou
