Gear fit 2 pro stopped tracking steps and HR
(Topic created: 01-15-2018 08:58 PM)
kitza
Gear and Gear Fit
I bough gear fit 2 pro from Samsung Shop Thailand since November. It's work properly until yesterday. While I running with gear fit, GPS not work so I reset gear. After reset It can not track step and HR but GPS still working. It has one more problem that it can't use motion to wake screen.
Model: SM-R365
Software Version: R365XXU2BQJ4
JUMP TO SOLUTION
DOSIrl
Gear and Gear Fit
Used chat. It was less than a year old, as all gear fit 2 pro's probably still are. It was released around the same time as the Note8
userSed93veDi9
Gear and Gear Fit
SM-R365
user6T9qK9Zm7m
Gear and Gear Fit
usermBlGyxzr5z
Gear and Gear Fit
I've had the same issue since somewhere october / december last year.
Step tracking has stopped working most of the time and whenever I try to launch a workout, the screen goes black and the workout doesn't start. Besides all this, on the rare occasions when I do get it to work (More on that below), it seems the floor tracking is off the charts. Even when I don't climb any floors during my use, I can easily get up to 22 floors in about 10 minues of walking on flat surfaces.
Over the past months I've noticed that I can get it to work randomly whenever the gear is completely drained and charged again. Alas that only seems to work for a limited period of time as after a day or 2 it stops working again. Normal charges don't do anything to resolve the issue and the drain-charge workaround that I had earlier doesn't seem to work consistently either.
Today I've finally tried a reset, but even though it did start counting steps and the workout app worked just fine again, it seems to be showing the same buggyness (weird floor tracking) and judging from this, there's a big chance it's going to stop working again in a day or 2.
For info:
-Model number: SM-R360
- Software: R360XXU1DQJ3
userrCNpM8KGd8
Gear and Gear Fit
Looks like mine flaked out Fri 3/23/18 - not long after a software update. Steps, HR & Sleep not tracking. Have cleaned contacts, turned off/on - no change, only thing I am getting is calories.
userlzfzlekPM1
Gear and Gear Fit
I faced the same issue. I bought my Gear Fit2 Pro in November in India. It was working fine.
On Saturday 7th April, 2018 it did not wake up once while cycling but was fine after that.
On 9th April it stopped waking up.
Today on 11th, I realized it has stopped counting steps and floors and HR.
I tried a lot of things and settings. I do not want to lose data by resetting it.
Model Number - SM-R365
Software Version - R365XXU2BRB2
user4nJL3AETjB
Gear and Gear Fit
4/11/18 - Unfortunately I’ve been dealing with this for several months also. Yesterday’s update did not help. I’ve even resorted to complaining about the app in attempts to get some response from anyone at Samsung. They told me to go to corporate and complain. I have the regular fit2 and have really enjoyed it over the couple different fitbits I’ve owned. Sad to see Samsung basically go the same route as my fitbits, into storage in my sock drawer.
I also tried the GPS trick mentioned below a few months back with no success.
4/14/18 - Update
Since my post from Wednesday I did a factory reset, turned it OFF (not soft reboot) then ON and drained the battery until it would not boot. Recharged, and it has worked properly ever since. Going on three days.
YourMomsWrath
Cosmic Ray
Gear and Gear Fit
It was working perfectly for about 6 month. Usually had the experience, that new updates would cause minor inconvenience, but nothing we couldn't handle. But this time, they Samsunged it up like pros. I nailed it down to that stupid Gear Fit update they threw out. So this time it's not the fault of the Cell Phone or App engineer section. But that being said, I'm entirely sure, some other things got messed up on phones and Shealth as well, that we haven't even figured yet.
Roll back on that stupid update of yours, because that's the source of all problems. Multi training feature? Wwhat the Samsung? I'm a triathlet, and I would never use your crappy wristband to document my trainings. Nothing a stop watch and Google maps couldn't do better. The only valid reason to keep the Gear Fit 2 on my wrist during trainings, was the constant, and up until now, very reliable heart rate tracking function. But since that, in combination with steps, and sleep being messed up, the whole purpose of the gear fit 2 is gone. Only thing I can use it from here, is to throw it into garbage. Thanks for enhancing my customer experience Samsung. I'm indeed very much grateful, for your continous and ingenuit inovations. Your engineers must be top of the branch for sure.
Just because you're paranoid, don't mean they're not after you!
userZ9MRcyc4aK
Gear and Gear Fit
Hi, I had the same problem, but the solution is very simple.
Just turn on the GPS for a while or start the "walk" training with the GPS enabled (only a few steps), then turn off the GPS (training and GPS off to save the battery).
After that everything started to work correctly. Cheers!.
usertd2aVfqtOT
Gear and Gear Fit
Having the same problem with my Gear Fit2 Pro. Only counting half my steps or some times none at all. Tried a soft reset, hard reset, turning on GPS, a "force stop" on my gear's "steps" app. Nothing is working. I thought Samsung was better than this.
