- Mute
- Email to a Friend
01-15-2018 08:58 PM in
Gear and Gear FitI bough gear fit 2 pro from Samsung Shop Thailand since November. It's work properly until yesterday. While I running with gear fit, GPS not work so I reset gear. After reset It can not track step and HR but GPS still working. It has one more problem that it can't use motion to wake screen.
Model: SM-R365
Software Version: R365XXU2BQJ4
Solved! Go to Solution.
- Mute
- Email to a Friend
04-24-2018 09:04 AM in
Gear and Gear FitIf you are still having this difficulty after attempting all of these troubleshooting steps, I would suggest that you reach out to 1-800-726-7864. They will be happy to help you with your repair options, @usertd2aVfqtOT.
If you need help with anything else, please let us know and our community will be happy to help!
- Mute
- Email to a Friend
04-25-2018 12:38 AM in
Gear and Gear Fit- Mark as New
- Mute
- Email to a Friend
05-12-2018 11:21 PM in
Gear and Gear FitHow did you go? I Tried a reset and it made no differences
- Mute
- Email to a Friend
04-25-2018 04:10 AM in
Gear and Gear FitThe heart rate monitoring, ppedometer and floor counter have all stopped working on my gear fit pro 2 also since i updated a couple of days ago. Ive tried reseting the device with no sucess.
Can you please provide a solution to this - I live in Ireland so I would rather not have to call a US number which will cost me a fortune just to be told to do all the things ive already done.
- Mute
- Email to a Friend
04-26-2018 09:06 AM in
Gear and Gear FitHey, @user4Sc8y4V0Zl, I really appreciate you reaching out to us about this. You can contact your regional support and they'll be happy to help you with this repair!
- Mute
- Email to a Friend
05-12-2018 11:24 PM in
Gear and Gear FitSame problem here from last Wednesday Australian time
- Mute
- Email to a Friend
04-29-2018 06:10 PM in
Gear and Gear FitI am confused as to why the watches may need repair. Mine had no issues until the update. Seems to be the same for a few of your customers. Surely this can be fixed with the app?
- Mute
- Email to a Friend
05-14-2018 09:00 AM in
Gear and Gear FitHey, everyone, I would suggest you follow the steps outlined above.
If you are still having this difficulty after attempting all of these troubleshooting steps, I would suggest that you reach out to 1-800-726-7864. They will be happy to help you with your repair options.
- Mute
- Email to a Friend
05-14-2018 06:42 PM in
Gear and Gear FitI took mine to the city service center - warranty repair expect to get it back working in a few days.
- Mute
- Email to a Friend
03-27-2019 07:23 AM in
Gear and Gear FitI just keep reading follow steps bove however I dont see any steps above to follow I am really needing help with this and it is makeing me not a happy person. worked fine did the update and that was it
