Highlighted
Not applicable
Gear fit 2 screen flickering on charge.
JUMP TO SOLUTION
My gear fit 2 has been working flawlessly. I love it. Then one day last week I put it on to charge and the screen started flicking very bright white light. It eventually stopped, and appeared to charge. When I tried to wear it the next day the screen would not work, and the device got very hot. After letting it sit all day, the screen started to work again but each time I try to charge it the same thing happens and it is broken for a few hours. I have done a factory reset and it hasn't fixed the problem.
1 SOLUTION
Highlighted
Re: Gear fit 2 screen flickering on charge.
JUMP TO SOLUTION
Are you using the original charger and cable? Have you tried another cable?
26 REPLIES 26
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
I am having the same screen flickering problem while charging. I'm using the original charger and I have tried another orginal charger that came with a different Gear Fit 2. It happens on both Chargers. I've done the factory resets as well and it still continues to have this issue.
Highlighted
JUMP TO SOLUTION
Can I have your full model code, serial number, and IMEI number (if LTE) via private message? http://bit.ly/2kZXrit
Highlighted
JUMP TO SOLUTION
Im having the same issue and have used nothing but the charger out of the box.
The infamous Galaxy Note 7 issue, a recently discovered Galaxy S10, S10+ and Galaxy S10e finger print flaw which the current fix is to use the flawed facial recognition until a patch comes out.  Now a problem with the Gear Fit2.  Not as though Samsung has a good history with hardware but of course this is a consumer problem until many more reports arise.
Highlighted
JUMP TO SOLUTION
@Patch207 I would be happy to assist you further. Can I please have your full model number and serial number in a private message: http://bit.ly/2JH2rq2
Highlighted
JUMP TO SOLUTION
Hello my Samsung gear fit 2 Pro is also showing a white screen I have all the original parts but it still isn't working is there something I can do?
Highlighted
JUMP TO SOLUTION
I'm having almost the exact same problem.  Just started a couple of days ago.  I can't even tell if it's actually picking up a charge.  I can't get it to reboot,  or maybe it's rebooting,  but i can't power it OFF. The screen flickers crazy on the charger,  and only portions of the screen are visible when I wake the face.
I can't find another, affordable version with similar enough specs for me to replace it yet,  so hopefully there's an actual fix? I'm using the original charger.  No physical damage,  normal wear.
Highlighted
JUMP TO SOLUTION
@LadyBrynna Can you send me a private message using this link here? Provide the following information
  • Model number
  • Serial number
Highlighted
JUMP TO SOLUTION
Hi Samgung Moderator,
I have the same issue with my Gear Fit Pro 2, I dont know why, but it started suddendly, can you help me with this issue? I really love the watch but I cant stand have it like this, specially since I use the original charger since the beginning, so far I have tryed to restore it as new, pair it to a different phone, both are Samsung (Note 10 + and Note 9), it is so annoying that the display bight is set to maximum and flickering while charging, no matter if the whatch is powered off or not, it works perfectly while is is showing the chargin progress but it always change the display brightness and flick while in waiting mode (when only the charging icon is been shown). I hope you can help me with this.
Best regards!
IC
