users2ZCvc7PVC
Gear fit 2 won't connect to MyFitnessPal or UnderArmor Record on iPhone. Also can't find Spotify.
JUMP TO SOLUTION
Hi everyone,
I'm hoping someone can help! I'm having pairing issues connecting my Gear Fit 2 to MyFitnessPal and UnderArmor Record accounts.  When I open the app on my Gear Fit 2, the screens load halfway and then says I need to pair my accounts.  I can't figure out how to initiate the pairing process.
I also can't find Spotify app when I launch the Gear Fit app and search for it in Samsung Galaxy Apps
Photos attached
More info on my setup
  • Gear Fit 2 connected to iPhone 8 plus
  • iPhone is signed into Samsung HealthGear Fit, UnderArmor Record, and MyFitnessPal
  • Fit Gear 2 has downloaded UnderArmor Record, and MyFitnessPal
  • iPhone is connected to Fit Gear 2. I can see battery percentage and everything
  • All of the apps are open in my iPhone when I try to launch the app on my Gear Fit 2
1 SOLUTION
users2ZCvc7PVC
Re: Gear fit 2 won't connect to MyFitnessPal or UnderArmor Record on iPhone. Also can't find Spot...
JUMP TO SOLUTION
It turned out the Gear Fit 2 itself needed a software update.  Once it updated, everything worked very smoothly.
Case closed.
2 REPLIES 2
JUMP TO SOLUTION
I would recommend reaching out to the developers of the apps for compatibility with your device. Please check out this link for compatibility of the gear fit 2 watches with iOS devices: https://www.samsung.com/global/galaxy/gear-fit2/device-compatibility/
users2ZCvc7PVC
JUMP TO SOLUTION
Case closed.
