- Mute
‎09-20-2017 10:11 PM in
Gear and Gear FitDoes anyone know how to set this up yet?
Solved! Go to Solution.
- Mute
‎11-12-2018 06:39 AM in
Gear and Gear FitThe guys at...
https://support.spotify.com/uk/contact-spotify-support/
...sorted this out for, really helpful
- Mute
‎07-12-2018 12:28 PM in
Gear and Gear FitI've been struggling with this for months. Finally logged in using my spotify username found on the web version of spotify (a series of numbers, NOT my email address) and my spotify password (which I had to reset since I'd been using Facebook to log in for so long that I forgot the separate spotify password). I chatted with a Samsung agent for over an hour about this and they were completely unable to help me, so hopefully this helps you!
- Mute
‎06-20-2018 07:53 AM in
Gear and Gear FitThere is no offline on my gear fit2 pro when I check settings. Only Stream on Wi-Fi and Remote. And remote is the only one working.
It will open Spotify on.my phone and play the music there. And I can see on all pc, phone and gear that one of my lists are downloaded as it's all green. If I turn off Bluetooth connection to the phone it tries to connect to Wi-Fi. It says it's connected and I need to log in to Spotify again. I do but then it says username or password is wrong. It isn't. Log in to Facebook. Getting frustrated. Only one working is adding physical songs to gear and listen through Bluetooth headphones without Spotify. Annoying since I bought premium because I love the idea of using it offline with gear when out walking/running.
- Mute
‎06-20-2018 09:20 AM in
Gear and Gear Fit@RNatalieN: Is the software of the device completely up to date?
- Mute
‎06-20-2018 09:55 AM in
Gear and Gear FitI bought it last day in May. And I've updated all I can update.
- Mute
‎06-20-2018 10:00 AM in
Gear and Gear FitCan I get the full model number of the device?
- Mute
‎12-04-2018 02:02 PM (Last edited ‎12-04-2018 02:25 PM ) in
Gear and Gear Fithmm, did someone of you really figured out how to listen to spotify songs offline?
I followed steps described on the first page. Download the playlist so that it shows that all is downloaded. Then I jump back to settings, activate Offline Mode, and music after some time the music stops.
Did someone of you really found out how to solve this issue? I still can´t manage to listen to music offline...
- Mute
‎02-29-2020 10:32 AM in
Gear and Gear FitExcellent run down. Same solution for Spotify on other wearables such as gear and active devices.
- Mute
‎05-13-2018 04:34 PM in
Gear and Gear FitI've spend hours trying to figure this out. I'm beyond upset. Won't allow anything to download and is stopping me even with wanting me to purchase the premium version. Not going to do that until I know this works. Not sure how to figure this out.
- Mute
‎10-04-2017 11:35 AM in
Gear and Gear FitThe Fit2 playlist title is a good suggestion, thank you!
