Highlighted
Gear fit2 pro wont turn on.
JUMP TO SOLUTION
I am unable to power on my gear fit 2 pro.
I have had this issue for a few months now and had just gone without the watch but finally decided to come here.
When I hold the power button it shows the first boot screen but on the second where it shows the samsung logo it shuts off.
I'm not sure how to fix this issue. Any help is appreciated.Only part of boot up that displays.Only part of boot up that displays.
1 SOLUTION
Highlighted
Re: Gear fit2 pro wont turn on.
JUMP TO SOLUTION
Thank you for reaching out. The watch will need to be serviced. You can call 1-800-726-7964 to set up an out of warranty repair or find an authorized service near you using this link: https://www.samsung.com/us/support/service/
1 REPLY 1
Highlighted
JUMP TO SOLUTION
