Gear s3 frontier battery drain
(Topic created: 08-07-2018 01:40 PM)
userwycC4G9lZi
Cosmic Ray
Gear and Gear Fit
Hi,
I am having an issue with my gear s3 frontier. The battery is draining with in few hours of full charge. I charged it to 100% by morning 8 am. I was using it during the day and by 1 pm, there is only 1% charge left and it shifted to power saving mode.  I experienced the same issue couple of days back too. This is a fairly new watch, I had purchased Gear s3 frontier in April 2018.
Please advise.
Thanks
userwycC4G9lZi
Cosmic Ray
Gear and Gear Fit
I recieved my watch after service. The problem was stated to be internal battery failure. They replaced the battery and so far it looks good. Though the question lingers my mind on how battery could fail in a new watch, I am happy that its resolved and watch is working great. Thanks for all the help.
SamsungAl
Gear and Gear Fit
Could you provide me with the model code and baseband version?
userwycC4G9lZi
Cosmic Ray
Gear and Gear Fit
Thank you.
Please find the information. Let me know if you need anything else.
Serial Number: R5AK303BEHM
MODEL NUMBER : SM-R760
TIZEN VERSION : 3.0.0.2
SOFTWARE VERSION: R760XXU2CRG3
SamsungMichelle
Red Giant
Gear and Gear Fit
@userwycC4G9lZi: Thank you for that information. Just to confirm, do you have any applications running in the background on the Gear itself?
userVUsCdEVBZZ
Gear and Gear Fit
Hi i am also having the same issue with battery draining insanely fast.
I recently purchased this watch (only a week ago) , the first day or so everything worked fine no issues with the life of the battery. I noticed after 3 days the sensors stopped responding so after searching online for solutions to that issue it lead me to doing a reset on the watch and uninstalling and reinstalling the gear software on my samsung s8 phone.
Doing this has done nothing to fix the issue and putting the phone on battery saving mode did nothing either! It still chewed through the battery regardless.
No apps running in the background , bluetooth turned off, wifi turned off, all the s -health tracking related applications off along with using the stock watch face after reset are not making any difference.
I have the same model/software as the above poster.
Whats the deal? when is there going to be an update regarding this issue as it seems there are plenty of people complaining about it.
Appreciate any advise you could give at this point as im starting to regret my purchase.
user1QrGtjIvi5
Gear and Gear Fit
Bezel or watch body may me warped bezel only works when tightly strapped on.
SamsungQue
Gear and Gear Fit
@user1QrGtjIvi5 Have you tried these troubleshooting steps here? http://www.samsung.com/us/support/troubleshooting/TSG01003232/
userwycC4G9lZi
Cosmic Ray
Gear and Gear Fit
No, there are no backgroud apps. I closed them all. Also, I am trying to recharge it now for last 4 hrs and its still at 26%. I am sure it recharges faster than that. At one point it was at 29% and now i see it gone down to 26% even while charging. How can this happen ? Could you please help.
userwycC4G9lZi
Cosmic Ray
Gear and Gear Fit
ok, i think I am following all those steps mentioned in the manual. The charging light shows up red. Its been 4 hrs and its still 28%, i think it never goes up beyond that. It still says charging and  1 hr 48 mins to fully charge. I will wait another couple of hours to see if it fully charges and then give an update here. Thank you !
