userHCGxzEmNyv
Re: Gear s3 frontier cannot disable alarm sync
You are right, as long as I connect the watch to my phone. The status changed back... very annoying. Now I just switch the watch off before I go to bed.
userzmlCG85uEG
Agreed very annoying and i have my watch charge overnight in another room which complicates the issue.
I only just updated my watch software earlier this week.  Prior to this it was never an issue.
I thought changing the watch sounds to mute would solve it but as others have mentioned, once it syncs again with my phone, its loud again.
How incredibly annoying and hope Samsung provide an update fix soon otherwise i may just switch my watch off overnight as well
userzMBFBARYew
How did you do this? I have same problem but cannot figure out how to mute the watch tone/vibrate.
gifham
yeah the workaround doesn't work.. it reverts back.
SunnyDay254Lyf
On Galaxy wear app, go to sync and turn off Sync to Wifi.
user4IABWhvvpE
and how does this help? i am connecting my watch to my phone by using bluetooth and the alarms are synching by using this method.
usereJwcONmJw9
I'm having the same issue. This is incredibly annoying. I certainly don't need 2 devices with an alarm, but what's worse is when my watch is charging in the other room and my phone alarm goes off but I have to run into the other room to shut off my watch alarm. I hope Samsung fixes this or gives us the option to disable syncing.
usera7ADSL4wqq
Same here - I wonder if and when it will fix because it is very annoying.
jahertor
Same here... It's a really annoying behavoir.
usercNy68C5RXp
Since the new update happened and it become verrrrry annoying. Samsung did fail this time and if they don't do something as soon as possible then will close my watch forever
