Highlighted
Re: Gear s3 wont turn on at all
JUMP TO SOLUTION
Could you send us a private message with your full model code and serial?
Highlighted
JUMP TO SOLUTION
I Have same issue. But I found a way to turn on watch.
1. Charge watch
2. Remove watch from charging tray.
3.  Place watch on charging tray again
4. When screen turns on and shows battery level, press and hold power button until watch turns on without removing wstch from charging tray.
You may need to repeat process 2, 3, and 4  for a few times.
Good luck!
Highlighted
JUMP TO SOLUTION
This solved it for me as well.
Thanks for the  solution bud. :-)
Highlighted
JUMP TO SOLUTION
Happened to me also.  Just got mine last December of 2018 as a gift, so out of warranty.  I was able to turn it on, but all sensor gone( step count,  heart rate monitor...etc), it is basically just a watch.  Then after 2 days it went dead completely and can't turn it on again.
Highlighted
JUMP TO SOLUTION
I'm having the same problem. Will not charge, turn on, or boot. I have only had it just over a year.
Highlighted
JUMP TO SOLUTION
Hey there!
Can you send us a private message with the below information here: http://bit.ly/2GH8URL
Model code:
Serial Number:
Highlighted
JUMP TO SOLUTION
I am having the same issue. Tried all if the above. It showed some sign of life then nothing. 11 months old and this seems to be a very common issue!
Highlighted
JUMP TO SOLUTION
Thanks a million I just recovered my watch through this method. Great help !!
Highlighted
JUMP TO SOLUTION
Trevor's solution worked for me!
Highlighted
JUMP TO SOLUTION
Screen turns off after rebooting logo, even if we keep pushing power button repeatedly. RIP gear s3 frontier after 1 year and 5 months
