Napapas
Re: Gear sport cannot be updated
JUMP TO SOLUTION
@SamsungJecca I'm sorry. I unintentionally touched the solve button.
The options on my watch when I go to settings> gear info are as below
-device information
-model number
-storage
-software information
-battery information
-open source licence
-report diagnosis
-debugging
JUMP TO SOLUTION
@Napapas; Thank you for providing me with that information. You can take the device to a Samsung Experience shop, inside a local Best Buy store. You can use the following locator in order to find the one closest to you. I would recommend calling ahead to verify they have a participating Samsung Experience shop first. You may also reach out to your local Ubreakifix at https://www.ubreakifix.com/   They may be able to assist you with a forced update. However, as you originally stated, the device may no longer be compatible.
Locator
Napapas
JUMP TO SOLUTION
Thank you for your advice. I have brought the gear to the service center. They have forced update the gear for me so everything is updated now and it seems to be more compatible between the gear and the phone due to this update.
JUMP TO SOLUTION
We're glad that you're up and running!
