11-15-2020 03:37 PM
Hi, my gearfit 2 won't charge at all and the battery is dead, I don't even see the lightening bolt for even a second when charging, I've cleaned the contacts used 2 different chargers, also a laptop, and put tried holding the buttons down to reset, nothing has worked so far, any help resolving this would be much appreciated
Solved! Go to Solution.
11-19-2020 11:34 AM
If your watch's battery is completely discharged, it will not power on. You'll need to charge it before turning it on. If the watch will not power on or if it doesn't seem to charge, the problem could be anything from the battery, connection, the charger, or the watch itself. Give this link a try: https://www.samsung.com/us/support/troubleshooting/TSG01003100/
If you are still experiencing these symptoms, I would recommend a service repair. Can you please provide me with the following information in a private message: http://bit.ly/2JH2rq2
Full Name:
Street address:
Email Address:
Best Contact Number:
Alternate Telephone Number: (If Available)
Model Code:
Serial/IMEI Number:
11-19-2020 11:34 AM
Full Name:
Street address:
Email Address:
Model Code:
Serial/IMEI Number:
