Phobia12
How do I locate the "map" feature on Gear Fit2
JUMP TO SOLUTION
Hello all..
   I'm in the need of some assistance with my fit2. I see this image on Samsung's site for the fit2. It has this map on it.  It round about talks about it... And was a huge selling factor when pitching these watches to my all powerful spouse.  I've looked up and down for this feature.  I've searched the Samsung app store.. And on Google search.  I need to find this map... or route tracker display.. or gps map.  What ever it is.  It's driving me nuts.  Please please help.. break it down Barney style for me.  It's  gonna help both me and my wife out. And i could use the brownie points.  I have gps activated, as well as wifi and blue tooth. But can't find this map.
Note Samsung... if you're gonna put this epic picture on the box.. you gotta make it easier to locate.  Cause perception is it's better than the rest.. And all I've found is its more accurate than my original fit.. And i like the bluetooth Spotify aspect.  Where's the map!!!!!
1 SOLUTION
Black Hole
Re: How do I locate the "map" feature on Gear Fit2
JUMP TO SOLUTION
Hey @Phobia12,
We are happy to see you actively participating in our community. You can activate the map feature on your Gear Fit 2. From the home screen, you should scroll to the left until you find the exercise option and select the activity type. Once you have selected the activity type, set target and turn on location. You will continue to scroll to the bottom until you see "view log." From here you will select the history of workout and scroll to the bottom for the map.
62 REPLIES 62
Black Hole
JUMP TO SOLUTION
Hey @Phobia12,
Kahtana
JUMP TO SOLUTION
So, it doesn't show you where you are going, or how to get there, it merely shows you where you have already been?
Jpsitof
JUMP TO SOLUTION
Correct.  So annoying.  Real time update of the map would be great.
userbw8IhuUPUd
JUMP TO SOLUTION
i read about that also, you have to download a navigation app, do not remember which one now, and it transfers the directions to your gear pro.  look online, that's where i saw it i believe or in the manual on the gear app.
JSchadewalt
JUMP TO SOLUTION
I have logged several runs, gone into the logs and there is never a map. my wife and I did a run together, her GF2 showed the map, mine did not. all setting on both devices are the same. any reason the map isnt showing on my device? it tracks everything else just fine.
areynoldsnz
Cosmic Ray
JUMP TO SOLUTION
It appears that the "auto" feature doesn't show a map. Did you manually start your run?
usereZnwkKAdSo
JUMP TO SOLUTION
I still can't get it on mine either.
tscribner
JUMP TO SOLUTION
There is no map at the bottom.  Now what?
userVbbA3tnOF0
JUMP TO SOLUTION
the fit2 has to be connected to an android phone to access a shot of the map Smiley Sad
