How to register the Galaxy Buds?
JUMP TO SOLUTION
I received my S10+ yesterday as well as my Galaxy Buds; the phone is registered but how do I go about registering the buds? I entered the S/N on the actual case and not the number listed on the box and the Samsung website states the S/N is invalid. Are we unable to register products we receive free or for promotional purposes?
1 SOLUTION
Re: How to register the Galaxy Buds?
JUMP TO SOLUTION
Can I please have the full model number and serial number for the galaxy earbuds in private message?
29 REPLIES 29
JUMP TO SOLUTION
Brandog_Medina
JUMP TO SOLUTION
Hey Adam could you help me out
user8Mv5CE90lE
JUMP TO SOLUTION
This doesn't help anyone else
userFnCcv1zQ8R
JUMP TO SOLUTION
Same issue here doesn't matter what number I put in it won't register. Can't find an answer from Google search either
userG0hPDwIm6w
JUMP TO SOLUTION
I'm having the same issue with my Galaxy Buds and the Wireless Charger Duo, and that I actually paid for. I'm wondering if it's because it's not marked as delivered under the my orders tab. I just received them today.
JUMP TO SOLUTION
Hey there @userG0hPDwIm6w, I'd like to look into this for you would you mind sending me a private message here with your full model codes and the serial numbers?
userJtzXweSakI
JUMP TO SOLUTION
I'm facing the same issue, please post if you find a solution, Thanks!
JUMP TO SOLUTION
I'm waiting a while before I try and register a second time.  With these being promotional I'm thinking we need to wait until everything at Samsung has been updated.
Tashala
JUMP TO SOLUTION
I'm having the same issue as well.
