Importing Cards to Samsung Pay
(Topic created: 04-04-2021 02:22 PM)
JADPhD
Gear and Gear Fit
I recently got a new S21 (Replacing my old S8 Active). Moving everything over was fairly simple but I've run into trouble getting my cards imported into my Gear 3 Frontier. I've gotten my AMEX into Samsung Pay on the phone,  but every time I try to import it to the watch I get "Failed to connect to card issuers server. Please try again." I've tried dozens of times.
Is there a fix or workaround?
SamsungAdam
Gear and Gear Fit
I would recommend reaching out to our Samsung Pay team directly at 1-844-726-7297 for further assistance.
SamsungAdam
Gear and Gear Fit
SamsungAdam
Gear and Gear Fit
An Accepted Solution has been marked, and provided for this thread. The thread will now be locked for further replies. in hopes to keep the integrity of the thread from steering in a non-technical manner. We understand the solution marked may not be a solution for everyone, If you have a separate concern or question, feel free to Private message a moderator or post a new thread with additional details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed in order to keep our community organized and make it easier for our users to find needed content. Remember that if you do make a new post, please include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring. Thank you for being part of the community!
