Highlighted
Is there a wake alarm
I just purchased the Samsung GearFit 2 Pro to replace my Fitbit Versa.  I went through the manual but can not find how to set up a wake alarm on the gear fit 2. Can you help?  I usually use my tracker as an alarm clock.  Thanks
4 REPLIES 4
Highlighted
Re: Is there a wake alarm
On your phone, if you go to the Galaxy store > search for alarm clock > tap on gear or watch, and install the alarm clock, do you see it on your watch?
Highlighted
I left off one bit of info.  I have an LG V20 phone and I couldn't find the app.  Is there a way to do it without a Samsung phone?  Thanks.
Highlighted
Do you have the Galaxy store on your watch?
Highlighted
Sorry no I don't have the Galaxy store on the Fit Pro 2. I am going to get a Samsung phone in July.  Thanks.
