Leaving Gear S3 on charger all night
(Topic created: 06-08-2019 08:32 AM)
userfYNJanxKiO
Gear and Gear Fit
Is it safe to leave my Gear S3 on charger all night?
Will that affect the battery with time? Or does it have auto cutoff?
GaryB82
Samsung Care Ambassador
Gear and Gear Fit
Yeah it's ok I leave mine on the charger sometime all night and the next day if I forget to put it on,  so far after 2 years I still see the same amount of charge I get around 40 hours of power
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "✓ Accept as Solution" button.
Gary-B82-Ambassador-Signature2Note 10+ Verizon Wireless
GaryB82
Gear and Gear Fit
userfYNJanxKiO
Gear and Gear Fit
@GaryB82 thank you for your reply :)
GaryB82
Gear and Gear Fit
Your welcome if you have any other questions feel free to ask and someone will help you
GHθST
Gear and Gear Fit
I have the new watch 42mm i do also, but also get a smart outlet to set a timer for charging. I have it for my phone (s10e) its actually not a bad idea :)
