GalaxyBud stopped working out of nowhere
(Topic created: 12-07-2019 02:07 AM)
MoisesC
Galaxy Buds
I put both buds to charge in the case, came back 2 hours and only the left one was fully charged. I left right earbud in there for another 2 hours n still no charge and the galaxy wearables app just shows an exclamation point for the right ear bud.
MoisesC
Galaxy Buds
both ear buds are in perfect condition, please help!
user0kuUs8l12d
Galaxy Buds
So what was the solution? Did he send them in to get serviced? If so, what part was replaced?
Hady_shabaan
Galaxy Buds
i fixed it my way ; check the video
https://www.youtube.com/watch?v=YIgv71BI4WM&feature=youtu.be
Repeat the steps if it didn't work from first time. Please comment if it helps " Subscribe " for updates if you want :D
MoisesC
Galaxy Buds
Still not working 😕
SamsungAdam
Galaxy Buds
Are you using the original charger that came with the Galaxy buds?
-If not I would recommend using the original charging cable.
Note: Use only Samsung-approved charging devices and accessories. Samsung accessories are designed for your device to maximize battery life. Using other accessories may void your warranty and may cause damage.
When did you start experiencing these symptoms?
Have you had a software update to your Galaxy buds recently?
Did the buds ever connect and charge?
Here's some tips and precautions when charging your Galaxy buds: https://www.samsung.com/us/support/answer/ANS00078081/
If you are still experiencing these symptoms after the troubleshooting provided, I would recommend a service repair.  You can use the following link to find a list of service centers in the U.S. that can do the repair: http://www.samsung.com/us/support/service/location or by contacting customer support at 1-800-726-7864.
For assistance outside the U.S., please use this link: https://www.samsung.com/us/common/visitlocationsite.html
user9TIiFIoDDh
Galaxy Buds
i bought my ear buds last month and they have been great however recently the right one stopped charging. any suggestions on how to get it working again?
MrZell
Black Hole
Galaxy Buds
Do the buds still connect to the wearables application, allowing you to reset using the wearables application?
user9TIiFIoDDh
Galaxy Buds
the right one is 100% dead. i tried to rest the set but it wont let me unless they are both atleast 30% charged.
usere0kq9HrOEe
Galaxy Buds
After trying all of the trouble shooting guides, my left ear bud is still not charging.
Help
