- Mute
01-18-2017 05:23 PM in
Gear and Gear FitMy headset has stopped charging and will not turn on. I've tried charging through different outlets and it's still dead in the water. I reached out to Samsung via chat and the guy I spoke to was less than helpful. Is there a hard reset for the EO-BG920 headset or some other trick that might kickstart it? I've had these things barely six months, they've not suffered any damage, and don't even use them that often, so I'm not too pleased at the moment.
Solved! Go to Solution.
- Mute
05-31-2018 07:22 AM in
Gear and Gear FitIt is not resetting. My headset is not pairing . Lights are not blinking for pairing
- Mute
07-01-2018 10:00 AM in
Gear and Gear FitThank you so much!! This worked for my headset!
- Mute
09-11-2018 01:29 AM in
Gear and Gear FitTried resetting using this solution. Doesn't work. When I pair the device not able to check 'Phone Calls'.
- Mute
01-08-2020 08:29 PM in
Gear and Gear FitIt is still not showing in my device.
- Mute
03-31-2020 01:12 AM in
Gear and Gear FitIt didn't help. I already did the hard reset a couple of times but nothing happened. It just won't work. Please help.
- Mute
05-17-2020 08:33 PM in
Gear and Gear FitHi,
There are two buttons for volume + & -, which one someone need to press & hold and for how long?
My headset is disconnecting again & again while on a call.
- Mute
02-20-2018 11:27 AM in
Gear and Gear FitI'm happy to help, @userKmUQKqqhoh, has your device ever powered on?
- Mute
02-23-2018 06:11 AM in
Gear and Gear FitHi to everyone
I can't connect my Level U pro to the Samsung Level App from playstore. The headset is connected to the phone, everything works, paired, but still can't connect to level app...
Any solutions?
- Mute
03-02-2018 10:13 AM in
Gear and Gear FitHI MY PHONE IS AN OLD- MODEL PHONE AND WHEN I WANT TO CONNECT MY HEADSET .PASSWORD IS REQUIRED WHAT SHOULD I DO??? HEADSET IS EO-BG920
- Mute
03-06-2018 08:20 AM in
Gear and Gear FitHey, I hope you are having a great day, @user3fk6L1vS6R. Have you attempted to put in 0000 as the password? This is a common Bluetooth pairing code when using a PC.
If this doesn't work, please let me know!
