Level U Headset hard reset
(Topic created: 01-18-2017 05:23 PM)
LeahTN79
Gear and Gear Fit
My headset has stopped charging and will not turn on. I've tried charging through different outlets and it's still dead in the water. I reached out to Samsung via chat and the guy I spoke to was less than helpful.  Is there a hard reset for the EO-BG920 headset or some other trick that might kickstart it? I've had these things barely six months, they've not suffered any damage, and don't even use them that often, so I'm not too pleased at the moment.
JUMP TO SOLUTION
Gear and Gear Fit
Hey, were you able to use this code to pair your Bluetooth headset to your PC?
If you need help with anything else, please let us know and our community will be happy to help!
userxRlSNAfmEM
Gear and Gear Fit
When I connect to the level u it just work for a second and then discount .  What can I do? Please help me.                  I even try resteing .
knightsurgeon
Neutron Star
Gear and Gear Fit
Would you reboot your phones into safe mode to see if you are able to pair your device? Putting your phone into safe mode will disable the third-party apps on your device from running and may improve your experience pairing the headphones.
To get into safe mode, just do the following: Power your device down>Then power it back on>Pressing and holding the Volume Down key when you see the Samsung logo
Let me know how this works
SamsungCat
Nebula
Gear and Gear Fit
@UserLevelPro please try the steps below to see if that helps.
userRuIzc3VtB8
Gear and Gear Fit
My headset is not connecting witj my mobile. And it is going sweatch off again and again. Plz reply me what i do
SamsungKim1
Supernova
Gear and Gear Fit
Have you tried the troubleshooting presented in this thread?
user9oUDR9Ux0r
Gear and Gear Fit
My samsung active level not charging
Not applicable
Gear and Gear Fit
@user9oUDR9Ux0r Have you tried using a different charger?
SamsungAl
Gear and Gear Fit
Have you tried to reset your network settings?
usermibmXXG690
Gear and Gear Fit
Hi In my Bluetooth headset the volume button not working ..call button also not working ...and if I atten call the opposite person cannot. Hear my voice ...
