- Mute
01-18-2017 05:23 PM in
Gear and Gear FitMy headset has stopped charging and will not turn on. I've tried charging through different outlets and it's still dead in the water. I reached out to Samsung via chat and the guy I spoke to was less than helpful. Is there a hard reset for the EO-BG920 headset or some other trick that might kickstart it? I've had these things barely six months, they've not suffered any damage, and don't even use them that often, so I'm not too pleased at the moment.
Solved! Go to Solution.
- Mute
09-28-2017 06:30 AM in
Gear and Gear FitGood morning, I am also having the same issue. I have A samsung S7 edge and Samsung Level Active Bluetooth Fitness Earbuds that I purchased about 3 months ago and they have been working wonderfully well until this morning. It was connected fine then disconnected it because I was going to charge the earbuds then after they were charged I try to reconnect them but they would not. I have tried the reset option listed on here with the volume and power button but it does not work. Not only can it not pair but it does not come up at all when I do a scan. Please help!
- Mute
02-24-2018 03:24 PM in
Gear and Gear FitThis helped me, hopefully it will for you.
1. Go to phone settings
2. Go to Applications
3. Press the 3 dot option button
4. Press Show System Apps
5. Go to Bluetooth
6. Storage
7. Clear storage
This should allow your headphones to pair to your phone
- Mute
02-25-2018 03:46 AM in
Gear and Gear Fit- Mark as New
- Mute
02-05-2020 11:20 AM in
Gear and Gear FitPress and hold the call receive key in your samsung level u headset for device discoverable.
- Mute
09-05-2020 12:49 AM in
Gear and Gear FitHi.
I just used your advise and....works!!!!:):):) Thanks for that.
By the way...maybe you will know... non of call recorders doesn't work on my samsung m31. Do you have any news what could work?
Kind regards
Andrew
- Mute
06-10-2018 03:40 PM in
Gear and Gear FitHi samsum... my Level U headset is not working... it stayed in white light and my phone cant find my blue tooth headset... what should i do
- Mute
11-13-2018 06:43 AM in
Gear and Gear FitMy Samsung Bluetooth pairing on my phone but call can't connect. How to solve this .pls help me
- Mute
09-28-2017 08:36 AM in
Gear and Gear FitHi, I posted on here earlier and did some more research and found this which resolved my issue. Hopefully it helps you as well.
Hold down the "Talk" button on the Samsung Bluetooth headset until that button is solid and not flashing, which should take roughly three seconds. This places yourheadset in Pairing mode. Hold down both of the volume buttons on the Samsung Bluetooth headset.
- Mute
10-03-2017 01:39 PM in
Gear and Gear FitMine also resolved by holding the answer button (not volume button)..
- Mute
09-26-2018 05:48 AM (Last edited 06-10-2019 11:14 PM ) in
Gear and Gear FitI have the same issue. what i did is, press the speak or answer button long for about 3 - 5 seconds while it is turn on and led light was blue and red alternately then switch off. Switch on again and it's working fine.
