Highlighted
Lost Notifications
JUMP TO SOLUTION
After the last update, I no longer receive notifications on my Gear 3 paired to Note9. I have reset my watch several times, run-paired and re-paired numerous times. Also reset the network as well. If I go to settings, connections, bluetooth, my watch says connection for calls. I no longer have audio and media.
Anyone else have a solution to fix the issue or is the $300 watch now worth $10?
1 SOLUTION
Highlighted
Re: Lost Notifications
JUMP TO SOLUTION
Can you please go to the Galaxy wearables app > click on notifications > click on Manage notifications > and make sure messages is toggled on? Then can you please go to the Galaxy wearables app > click on notifications and send me a screenshot of the settings?
6 REPLIES 6
Highlighted
JUMP TO SOLUTION
Are you using the stock messaging app on your device?
Highlighted
JUMP TO SOLUTION
I have switched back to stock and still nothing. I have checked the Connection, Bluetooth Gear Icon and it no longer has audio and media. Just says Connected for Calls
Highlighted
JUMP TO SOLUTION
Are you using the Galaxy wearables app on your note 9?
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
I deleted the other messaging app that I was using and made sure all settings are on for the standard default messaging app and now appears to be working. Apparently there was a glitch between the 2.
Thank You for the Samsung Support
Highlighted
JUMP TO SOLUTION
You're most welcome. Please reach out if you need assistance in the future.
