usermjtNUUxwbM
Mesh cleaning and replacement kit
I am trying to get the mesh replacements for my Gear Iconx 2018. I have called Samsung customer support and they referred me to service parts for them to turn around and say they do not distribute the mesh kits separately. Can somebody please guide me in the right direction because this is frustrating.
3 REPLIES 3
Samsung Care Ambassador
Re: Mesh cleaning and replacement kit
I would suggest reaching out to one of the Forum Mods they should be able to help you with replacement mesh kits i'll tag them so they will see your post hope they are able to help you with your problem
@SamsungRei   ,    @SamsungCole
If you've found my post to be helpful, please like the post. If my response resolved your issue, please mark it as "Solved."
Note 9 User
Note 9 User on Verizon Wireless
Hey there!
@usermjtNUUxwbM, Can you please send me a private message with the below information here at this link: http://bit.ly/2GH8URL
Model code:
Serial Number:
VladB
I'm in the same situation however I'm 2 months outside the warranty period and understand I need to buy the parts but can't do so through J&J Electronics (aka SamsungParts.com). I'd be super grateful if one of the forum mods can PM me. Thanks!
cc: @SamsungRei @SamsungCole
