Highlighted
Messages aren't deleted from phone when deleted from gear s2
JUMP TO SOLUTION
1 SOLUTION
Highlighted
Re: Messages aren't deleted from phone when deleted from gear s2
JUMP TO SOLUTION
Hi @user8ZJ0sqjXzw Do you have your Gear S2 synced with your device? Would you mind sending me the model number and Baseband version for the Gear as well as the phone it's connected to?
6 REPLIES 6
Highlighted
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
It is synced
Phone
Model SM-G950U
Baseband Version G950USQ2BQK5
GEAR S2
MODEL. SM-R730A
Highlighted
JUMP TO SOLUTION
Thanks for that information @user8ZJ0sqjXzw Your phone appears to be running up to date however I do see that AT&T recently pushed an update out for your Gear. For more information and instructions on how to update your gear, please check out their site: https://www.att.com/devicehowto/tutorial.html#!/stepbystep/id/stepbystep_KM1147956?make=Samsung&mode...
Highlighted
JUMP TO SOLUTION
Hi,if messages always can't be deleted ,I suggest you use an Samsung Eraser.
But it is more troublesome than deleting it directly on your phone.
You need download it on youe computer and connect your device to computer,then the program will scan your files ,and you can choose delete your messages.
