My Gear Fit 2 doesn't appear to be charging and won't turn on
(Topic created: 12-26-2016 09:55 AM)
userRJ6xcOgU4U
Gear and Gear Fit
It's a model SM-R360ZINXAR, Serial No. <Hidden>.  I press and hold the side buttons (individually and together) for long periods of time (30 plus seconds), nothing.  Put on the charger and it shows a white lightening bolt for maybe a second, then nothing.  Opened it up for the first time yesterday, so don't have experience with it working before. Left it on the charger overnight last night, nothing still this morning.  Help!
SamsungViv
Honored Contributor
Gear and Gear Fit
Hello there, @userRJ6xcOgU4U and @userMQ03PryjmV. We're glad you reached out here with your concern.
Try opening up the device you have the Gear Fit 2 paired with and unpair the two. Give the phone a moment or two, the try repairing them. Afterward if you try to turn on the Gear Fit 2, hopefully it will turn on just fine.
If this doesn't help, we certainly want to assist you further with this matter. To better do that, can we have some added details about your specific device and this concern? Things that will help the most would be the exact model number and Baseband version (both under Settings>About Device) for your device as well as what smart phone your device is paired with, when you started noticing this happen, and what you've already tried to fix it. Thanks!
userRJ6xcOgU4U
Gear and Gear Fit
userszAjN6pCWS
Gear and Gear Fit
Press both buttons down together and hold....it should reboot.  This worked for me.
techie127
Cosmic Ray
Gear and Gear Fit
Awesome. Thanks
usersJ6I0IJ1Ho
Gear and Gear Fit
this worked for me as well.
userHGML54wBuA
Gear and Gear Fit
Thanks this worked for me..
DukeofHops
Gear and Gear Fit
This did not work for me. I haven't used the watch for a couple years. It's been sitting in a drawer. I currently have it plugged into my computer as I remember that was the best way to start charging when totally dead. Any other suggestion?
Knowaczark
Gear and Gear Fit
Thanks!!! Worked for me...Smiley Happy
userMQ03PryjmV
Gear and Gear Fit
Am experiencing the same thing.  Just bought mine and tried to turn it on by pressing the power button.  Nothing but black screen.  So I figure it just needs to be charged.  I connected it to the cradle.  The lighting bolt icon comes on for a second then dissapears.  Doesn't look like its charging.
Model Number: SM-R360ZINXAR
SamsungViv
Honored Contributor
Gear and Gear Fit
