Highlighted
Re: My Gear Fit 2 doesn't appear to be charging and won't turn on
JUMP TO SOLUTION
Mine has been doing the same thing. It is not paired with any other devices. What can I do now? Model SM-R360
Highlighted
JUMP TO SOLUTION
How do you "unpair" them?
Highlighted
JUMP TO SOLUTION
My Gear Fit 2 is exactly 1 year old. As of today it will not charge. I have paired and unpaired it several times. I factory reset it twice. It is now down to less than 5% battery life. This is ridiculous. I may have to go back to a Fit bit.
Highlighted
JUMP TO SOLUTION
I'm having the same problems as those above, and I've tried everything you suggested above.
My model number: SM-R3600DAAXAR
SKU: SMR3600DAAG
Serial No: R5AH5017WJY
Is there a way to get a new one?
Highlighted
JUMP TO SOLUTION
I wish I knew.  My gear fit 2 wont turn okn and won't charge, nothing works, it's essentially a $150 piece of trash.  Samsung should offer some resolution to this all too common problem, yet I have heard nothing that has helped me thus far.
--Very Disappointed and i am not going to purchase any more Samsung products
Highlighted
JUMP TO SOLUTION
Thank you! Unpairing and pairing again worked perfectly.
Highlighted
JUMP TO SOLUTION
As the device cannot be charged it also cannot be paired so this advice makes no sense. I am experiencing the exact issue & have tried all recommended solutions as well without any resolution.
Highlighted
JUMP TO SOLUTION
Hi mine is doing the exact same thing. Have tried the recommendations given..
Model SM-R360
FCC ID - A3LSMR360
S/N - <Hidden>
Charging dock
Ep-YB360
S/N -<Hidden>
Look forward to response..please email me on troyandbec@outlook.com
Thankyou
Highlighted
Supernova
JUMP TO SOLUTION
I am sorry to hear this. Just to confirm, did you try cleaning the charging port on the device as well as the charger?
Highlighted
JUMP TO SOLUTION
Yes
