Highlighted
Honored Contributor
Re: My fitness pal and s health syncing?
JUMP TO SOLUTION
I recommend reaching out to our Samsung Health experts. They can be reached 1-800-SAMSUNG.
Highlighted
JUMP TO SOLUTION
You need to go to setting on the Samsung health app, then select the 3 dots on top right, then select settings. Then scroll down to connected devices, then make sure the green dot is on for Strava, you will need to click it to turn it green., You will also need to sign up. Next scroll down to data permissions and select my fitness Pal. Make sure all the boxes where is says allowed to read are ticked and it should now work. Hope that helps.
Highlighted
JUMP TO SOLUTION
I was having this same problem until a this afternoon and accidentally found the following fix by trial and error...
In Samsung Health, tap on the 3 Green Dots on the upper right side of your screen, click on SETTINGS, scroll down and click on DATA PERMISSIONS, click on MYFITNESSPAL, and make sure it and everything I wanted to sync between the two apps was turned on (it will be grey if off and green if on)
Not sure if this will work for you, but always worth a try.
Highlighted
JUMP TO SOLUTION
Yep, this did the trick for me too.
Thanks a lot for sharing this solution !
Highlighted
JUMP TO SOLUTION
It still wont add MFP
Highlighted
JUMP TO SOLUTION
I bought a gear sport watch and have managed to link s health and MFP, however, the steps linked are from my phones internal pedometer, Not the step count from my Samsung gear sport. I have selected Samsung tracker as an option  for where MFP adds steps from but it is choosing S Health rather than the tracker steps.
Please help!
Highlighted
JUMP TO SOLUTION
I have done all this and still not working, not sure what else to do to be honest.
Highlighted
JUMP TO SOLUTION
I don’t have the 3 dots anywhere in the Samsung Healtb app. How did you get to those?
Highlighted
JUMP TO SOLUTION
This advice solved my issue with the syncing.  Thanks!
Referring to this advice:
In Samsung Health, tap on the 3 Dots on the upper right side of your screen, click on SETTINGS, scroll down and click on DATA PERMISSIONS, click on MYFITNESSPAL, and make sure it and everything I wanted to sync between the two apps was turned on (it will be grey if off and green if on)
Highlighted
JUMP TO SOLUTION
My Gear 2 did an update the other day and since the step counter will not sync from SHealth to MFP.  Any ideas??
