Highlighted
New gear fit 2 pro will not charge or turn on
JUMP TO SOLUTION
Just bought a new gear fit 2 pro and it will not charge or turn on.  It is brand new, out of the box, never been paired with anything.
1 SOLUTION
Highlighted
Re: New gear fit 2 pro will not charge or turn on
JUMP TO SOLUTION
If your watch's battery is completely discharged, it will not power on. You'll need to charge it before turning it on. If the watch will not power on or if it doesn't seem to charge, the problem could be anything from the battery, connection, the charger, or the watch itself. Give this link a try: https://www.samsung.com/us/support/troubleshooting/TSG01003100/
If you are still experiencing these symptoms after trying the troubleshooting shooting steps provided, I would recommend a service repair. Can you please provide me with the following information in a private message: http://bit.ly/2JH2rq2
Full Name:
Street address:
Email Address:
Best Contact Number:
Alternate Telephone Number: (If Available)
Model Code:
Serial/IMEI Number:
1 REPLY 1
Highlighted
JUMP TO SOLUTION
Full Name:
Street address:
Email Address:
Model Code:
Serial/IMEI Number:
