New phone how to connect
(Topic created: 05-10-2021 11:43 AM)
bbobo
Gear and Gear Fit
Says I have to disconnect fit2 from old phone in app before can connect to new phone. The old phone was lost so what is the next option
bluis
Gear and Gear Fit
Boobo found it. If you haven't. Swipe down screen on you fit2 from top . Slide left till you see the restart & reset. Tap rest. That's it. Connect yo your phone. Take 30secs.
Adaboy
Supernova
Gear and Gear Fit
I would uninstall and reinstall the app see if that works.
bluis
Gear and Gear Fit
I'm having the same issue bbob. This is obviously no help. Reinstall the app. Hahaha.I'm sorry but did you read the question Adaboy? It won't connect cause you can't disconnect it from the app. SMH.
bluis
Gear and Gear Fit
userdVw6zSD2LR
Gear and Gear Fit
We can not swipe down the screen, it seems that it is blocked as it only appears a message " no notifications", "connect to a phone".
Thanks!
