Highlighted
Recent Gear S3 Frontier update to R760XXU2CRG3 issues
JUMP TO SOLUTION
Hello,
I just recieved my Gear S3 Frontier a couple days ago, model SM-R760NDAAXAR. I followed the steps in the "Quick Start Guide", and paired the watch to my Note 8. Everything worked great for 2 days. Heartbeat sensor, sleep recording, autolock. Then this morning, the watch updated to R760XXU2CRG3 TIZEN 3.0.0.2 I cannot make the watch see my heartbeat, the sensor on the back goes dim, then turns back on. The battery consumption is immense. It takes forever to charge while it's on. The watch gets hot while charging now. I am not sure what to do now. I just spent $270 on a watch that worked for 2 days, only to have an update to come out and ruin it.
Please tell me that I am not the only person that is having this issue.
Thank you in advance.
1 SOLUTION
Highlighted
Re: Recent Gear S3 Frontier update to R760XXU2CRG3 issues
JUMP TO SOLUTION
So I think I fixed my issue. All I did was power the watch off after resetting it, and kept it off for the night. Turned it back on, paired to the phone and am not having issues anymore. Aside from the annoying Samsung account notification each time the bletooth connection is lost.
24 REPLIES 24
Highlighted
Supernova
JUMP TO SOLUTION
I am sorry to hear this. Have you tried clearing the Cache on your mobile phone?
Highlighted
JUMP TO SOLUTION
Buy my Gear S3 in February of this year.
Happy to see that he had an autonomy of 3-4 days.
Last week it was updated and changed to 8-9 hours.
Yesterday, I was upgraded again to R760XXU2CRG3 and it is the same.
In short, go from 3-4 days to 10 hours
Well, with the clock in airplane mode.
Consumed 10% per hour.
Please, do not tell me it's because it hurt.
It was very clear that the consumption changed after the update.
I believe in coincidences, but not so much!
THE CHANGE WAS VERY CLEAR!
Actions
Unplug the watch from the phone.
Clear cache of everything
Uninstall all of the phone (Gear, Gear S plugin, S Health)
Reset of the clock.
Tests
Connection only with Bluetooth
WiFi disconnected
full cycle in airplane mode.
charge from 0% with the clock off.
All the same, always 10% per hour.
Summary
10% per hour
Any suggestions would be welcome.
Highlighted
JUMP TO SOLUTION
Highlighted
Supernova
JUMP TO SOLUTION
@user5OwT1BhCN2: Thank you for sharing. Smiley Happy Please keep us updated.
Highlighted
JUMP TO SOLUTION
This none of these fixes have fixed my sensors.
When is there going to be a proper fix from Samsung?
Highlighted
JUMP TO SOLUTION
I recieved my watch as a gift brand new 4 days ago. Went through start and setup procedure and my sensors do not work at all. I've scrolled through the suggested recommendations to solve the problem but none have work. please help, cant take it back to store as I dont have a gift recipet and friend that got it for me cant find the original, so the store refuses to help.
Highlighted
JUMP TO SOLUTION
New test ..
Charged 100%, removed from the charging base and placed overnight next to the phone. (While sleeping)
Without any kind of use, screen on zero times.
After 7 hours I am at 35%.
Watch face 20%
Samsung Health 7%
notification 4%
adjustments 4%
Galaxy Apps 3%
Music 2%
Highlighted
JUMP TO SOLUTION
@user5OwT1BhCN2
Try this too and without success
Highlighted
JUMP TO SOLUTION
Go to connections scroll down to Bluetooth Alerts you can turn it off there.
