- Mute
‎01-20-2017 03:12 PM (Last edited ‎12-04-2023 12:11 AM by SamsungChelsea ) in
Gear and Gear FitMy Gear S2 (non phone version) has been running with no battery issues where it would last up to 36 hours. Bluetooth active, Sleep as Android etc. I started to get a cache full on my S7 in late January 2017 so I told it to clear cash and it seemed to start the problem. I did have music on my watch and had about 1 gb of memory left.
The battery started to last maybe 5 to 6 hours. I did a full reset/rebuild on the watch and went to base settings but it only added a couple of hours.
Based on use and past performance I have to believe that it was a recent update to either the watch or phone.
Please advise as to issue cause and how to restore the watch to it's former battery capacity.
Gear 2
model SM-R732
Tinzen 2.3.2.1
SoftwareR732XXU2EPK5
Knox 2.0.0
Knox Tinzenwearable 1.0.0
Tima 3.0.0
Galaxy S7 edge
Gear App
Device SM-G935P
Device Name: Gear S2 8CD3
Samsung gear app - 2.2 16101261
Gear S Plugin - 2.2.03. 16111661
Solved! Go to Solution.
- Mute
‎05-12-2017 08:47 AM (Last edited ‎05-12-2017 08:47 AM ) in
Gear and Gear FitI also have the same issue!
SAMSUNG: OBVIOUSLY THIS IS A KNOWN ISSUE
Why don't you admit this and UPDATE US on the progress for a fix?
Stop the runaround! Everybody who owns an S2 knows about the occassional day were the battery just randomly drains in the span of a few hours from 100% to 0% for no apparent reason.
- Mute
‎07-03-2017 05:47 AM in
Gear and Gear FitI have the same issue. I have had my watch for 4 days and i had to charge it 3 times in one day. Not a great selling point. I did a factory reset. Set it up with my phone and did not do the update. Then disconnected it from my phone. So far it's perfect. I messaged samsung and hopefully this helps.
- Mute
‎07-13-2017 08:53 AM in
Gear and Gear FitAt this point, Samsung should replace this product. I am going to blast this information to every blog, dashboard, and competitor possible until I get answers. People I know with Apple watches don't have this issue, why should Samsung. I paid too much $ to have this issue in such a short amount of time with this watch. If enough people in the public know this issue and stop buying this watch, then they will finally address the issue
- Mute
‎07-17-2017 11:45 AM in
Gear and Gear FitI came to this thread because I was having the same issues. When I realized that no one had a fix for the draining issue I contacted Samsung expert support in this app and after many different steps with an expert I believe my gear s2 has stopped draining the battery in four hours. I strongly suggest you talk to the experts.
- Mute
‎07-17-2017 01:05 PM in
Gear and Gear FitI am having this same problem. I have had my s2 for 2 years and no battery problems. Since Friday I get this white screen over the top and it flickers on and off and my battery is drained in 2-3 hours. It is paired with my Galaxy S6 and my watch does not have the phone capability.
What's the solution Samsung?
- Mute
‎07-25-2017 11:05 AM in
Gear and Gear FitI just started having issue in last 2 days. No change to apps, but battery draining on S2 Classic in 5-6 hours
S2 Classic
Note 5
- Mute
‎07-28-2017 07:59 AM in
Gear and Gear FitWhat did they have you do?
- Mute
‎07-29-2017 07:33 AM in
Gear and Gear FitThe one thing that I have done, because there is nothing official from Samsung, is to turn my watch off each night when I go to charge it. In the past few months the only time this didn't work is when I had to many pop-up notifications that kept coming on and because I had a customer visiting I just kept snoozing it. Otherwise, I am able to go a full day and sometimes extra when traveling.
- Mute
‎08-03-2017 08:00 AM in
Gear and Gear Fit--- This is NOT a device-end issue or there wouldn't be multiple users with same complaint. Obviously a firmware update broke it. Battery drain and constant BT disconnects not to mention it never reconnects after leaving and returning from phone range.
- Mute
‎10-04-2017 08:30 AM in
Gear and Gear FitI was having the same problem, so I tried draining the battery to zero and then recharging fully. It seems to have done the trick!
