- Mute
‎01-20-2017 03:12 PM in
Gear and Gear FitMy Gear S2 (non phone version) has been running with no battery issues where it would last up to 36 hours. Bluetooth active, Sleep as Android etc. I started to get a cache full on my S7 in late January 2017 so I told it to clear cash and it seemed to start the problem. I did have music on my watch and had about 1 gb of memory left.
The battery started to last maybe 5 to 6 hours. I did a full reset/rebuild on the watch and went to base settings but it only added a couple of hours.
Based on use and past performance I have to believe that it was a recent update to either the watch or phone.
Please advise as to issue cause and how to restore the watch to it's former battery capacity.
Gear 2
model SM-R732
Tinzen 2.3.2.1
SoftwareR732XXU2EPK5
Knox 2.0.0
Knox Tinzenwearable 1.0.0
Tima 3.0.0
Galaxy S7 edge
Gear App
Device SM-G935P
Device Name: Gear S2 8CD3
Samsung gear app - 2.2 16101261
Gear S Plugin - 2.2.03. 16111661
Solved! Go to Solution.
- « Previous
- Next »
- Mute
‎10-08-2017 12:47 PM (Last edited ‎10-08-2017 01:26 PM ) in
Gear and Gear FitNothing seems to work for me. I have uninstalled the app, reset the watch. Removed all apps and notifications, even have a straight black watch face. My battery is drained in 4 hrs. This all started suddenly about 10 days ago. This is an ongoing problem and it needs to be addressed by samsung. I don't know why they aren't fixing this. I saw in another thread that they admit to this being an issue.
- Mute
‎10-09-2017 09:29 AM in
Gear and Gear FitSame issue for me, nothing works. Today 100% charge to 0% in 3 hours! Other days it lasts several hours. Have removed all apps, non-Samsung Watch faces, etc. My smartwatch is now a dumb watch with no success in keeping battery life!
- Mute
‎01-25-2018 06:56 PM in
Gear and Gear FitI have had this same issue. I haven't done anything different. My phone just started dying for no reason.
- Mute
‎03-23-2018 07:40 PM in
Gear and Gear FitI've had the same issue and nothing has fixed it. I don't have any extra apps and went to factory. It's never last more than 8 hours.
- Mute
‎04-04-2018 08:56 AM in
Gear and Gear FitI put it in airplane mode - it still gets messages over Bluetooth but wifi sync is turned off. Seems to have helped.
- Mute
‎04-05-2018 04:52 AM in
Gear and Gear FitAirplane mode seems to have sorted it - 23% battery drain in 6 hours. I'm guessing it's the wifi connection causing the issue.
You still get notificaitons in airplane mode - Bluetooth isn't turned off.
- Mute
‎02-15-2019 09:33 PM in
Gear and Gear FitI have given up. I've had my watch for approximately 2 years and now it's hit or miss if the battery will last 4 hours or 24 hours and I rarely get notifications anymore from the watch. I got a good deal on a new galaxy watch and am going to retire my S2 classic to the trash heap. I'm afraid this is a lost cause.
- Mute
‎12-23-2019 12:17 AM in
Gear and Gear FitI've had the same problem, it started last year. I should say that I got the watch in January 2016.
Since last year the battery wouldn't last more than 9 hours. I asked Samsung for a solution, they said to perform a factory reset, but the situation was the same.
Eventually, I deactivated Samsung health, turned off wi-fi and anything else that would drain the battery and now I am very happy to say that the battery lasts for aprox. 24 hours.
- Mute
‎05-08-2021 02:54 PM in
Gear and Gear Fit
- « Previous
- Next »
