userF8QLMbwvkP
Samsung Gear S3 Battery Issues solved
On June 8th I received a sizeable update to the Wear app and the watch. I have gone from 8 hours of battery life to 32 hours, with all my apps loaded on the watch. Looks like Samsung has begun rolling out a solution to the battery drain issue. Thank you Samsung.
1 REPLY 1
jrmoscosoa
Re: Samsung Gear S3 Battery Issues solved
I had the same update without resolving my problems.  My Frontier is turning 3 years and have been acting strangely for the last months. After some 4 to 5 hours of use it will turn off apparently because of a low battery which will show on the gear screen as anything from 60 to 40%. When I put it back in the charger, the screen will flash stating battery level in or around 80% and minutes to complete charged. Is this something related to the OS or the battery is showing its age? My Gear SN: R5AJ20BXJ5W
JRMA
