ERNDAWG54
Samsung active 2
This new watch, my question is can the display be locked manually.
2 REPLIES 2
Re: Samsung active 2
@ERNDAWG54
Set a screen lock
It is recommended that you secure your device using a Screen lock.
1.
From Settings, tap Security > Lock.
2.
  • Tap Type to select a screen lock type:
  • Pattern: Create a pattern that you draw on the screen to unlock your device. This option provides medium security.
  • PIN: Set a PIN to use for unlocking the device when it removed from your wrist and the screen is turned off.
  • None: Do not lock the screen.
3.
Tap Help to view help information for using the screen lock feature.
ERNDAWG54
The active 2 isn't available yet. I was just asking if th...
The active 2 isn't available yet. I was just asking if the screen on the watch can be locked. Last Samsung watch i had i had to return it because i couldn't lock the screen
I wear a ESD smock at work and the sleeve interferes with the watch.
