Samsung gear s3 won't charge and turn on even with 80% battery
(Topic created: 12-05-2020 07:59 PM)
userRFDbfnaWMR
Gear and Gear Fit
My samsung gear S3 stops working after the latest software update. It will work for 30 seconds in the charger and say it's 80% charge then when I turn it on it shuts off whenever I try to do something with it. Please help.
SamsungAdam
Gear and Gear Fit
If your watch's battery is completely discharged, it will not power on. You'll need to charge it before turning it on. If the watch will not power on or if it doesn't seem to charge, the problem could be anything from the battery, connection, the charger, or the watch itself. Give this link a try: https://www.samsung.com/us/support/troubleshooting/TSG01003100/
If you have tried the troubleshooting steps provided and are still experiencing these symptoms, I would like to look into further options. Can you please provide me with your full model number and serial number/IMEI in a private message: http://bit.ly/2JH2rq2
SamsungAdam
Gear and Gear Fit
Sheeshkibob
Cosmic Ray
Gear and Gear Fit
join the club, it's a big software fiasco being brushed under the carpet. I like how they flagged it as Solved !! very sneaky ! a lot of posts regarding this issue have been flagged as solved.
Can you confirm that your issue has actually been Solved ?
Thank you
userRFDbfnaWMR
Gear and Gear Fit
Nothing happened. My watch still won't turn on.
