userJjXz3CLJD0
Samsung level U getting disconnecting & reconnecting automatically.
Hi Team,
I am using Samsung level U blutooth device. Its getting disconnect & reconnecting automatically frequently. What could be the probable reason?
It has nothing to do with distance. Its always on my neck & phone in my hand and not even driving.
5 REPLIES 5
Re: Samsung level U getting disconnecting & reconnecting automatically.
Have you tried resetting the network settings? Just a heads up, by resetting the network settings, it will remove all wi-fi and Bluetooth settings you currently have saved.
userJjXz3CLJD0
I already tried. But no luck. I even used this device on laptop. Same issue persist.
Have you tried resetting the level U headphones?
userJjXz3CLJD0
I tried like hold the call button for a minute. Green light starts blinking. Is there any other way to reset?
Thank you for that information. Can I please have your full model number and serial number in a private message: http://bit.ly/2JH2rq2
