Samsung_c2Eh17S
Serial number for Samsung earbuds
The numbers on tube case of the Samsung Buds do not qualify for the registration on the member app. What is the number? Exasperated!!
3 REPLIES 3
Samsung Care Ambassador
Re: Serial number for Samsung earbuds
At the time you cant register Samsung Buds since they are listed as accessories hopefully that will change in the future
If you've found my post to be helpful, please like the post. If my response resolved your issue, please mark it as "Solved."
Note 9 User
Note 9 User on Verizon Wireless
I was able to scan the bar code on the box when registeri...
I was able to scan the bar code on the box when registering and it worked. Any of the 2 S/N numbers on that label should work.
@Samsung_c2Eh17S  Try the bar code for the right ear bud see if that works i know of last week they wasnt able to be registered i just tried on a new pair and it would only accept the right ear buds serial number
Note 9 User
