- Mute
- Email to a Friend
11-30-2020 07:52 AM in
Gear and Gear FitMy gear fit 2 pro watch, after the configured sleeping delay (15 seconds) will shut down completely instead of going to sleep. So I always have to power on every time. When I keep playing with the user interface and touch screen, it will work until the idle delay is reached. Then it will shut down.
I tried almost everything, from updating, rebooting, reseting, installing older, newer firmwares, changing the battery, disconnected and reconnect the battery few times.
Any suggestion?
Thank you!
- Mute
- Email to a Friend
12-04-2020 01:10 PM in
Gear and Gear FitThank you for reaching out. I would be happy to assist you further. Can I please have your full model number and serial number/IMEI in a private message: http://bit.ly/2JH2rq2
