Sync Samsung health with Noom
(Topic created: 08-14-2019 01:36 PM)
userAWy4mJBAZ6
Gear and Gear Fit
Samsung needs to update and allow permissions to sync all info with apps like noom and googlefit.
My samsung gearfitpro2 watch can sync with Samsung health, but only weight data will sync with noom. This is frustrating because it should be able to sync all food, steps, heart rate data as well.
Please FIX this issue fast.
user8GNCjEVifa
Gear and Gear Fit
Totally agree with the above! I have the same issue with the Active 2. May need to go back to my Fitbit watch! 😞
Please FIX this issue fast!
SamsungAdam
Gear and Gear Fit
I would recommend reaching out to the developers of Noom to verify compatibility with your device.
userZonTBps0oc
Gear and Gear Fit
SamsungAdam,
I have a Gear S3 Frontier connected to a Galaxy S10+. Noom states Samsung Health on the Galaxy S10+ should sync; steps, weight, food logged, and ony other "activity" such as a run or workout.
This is not happenihng, all sync settings are turned on in Noom and Samsung Health to "properly" sync. Nothing is syncing with Noom from Samsung Health?
Noom sent me back to Samsung.
Thanks,
Scott
SamsungAdam
Gear and Gear Fit
Thank you for that information. I would recommend reaching out to our Samsung Health team directly at 855-795-0509.
user2Whfupxz3p
Gear and Gear Fit
Do you have an email address. I am not willing to ring the USA to discuss this malfunction. I would not have bought this Active 2 if I had known it could not sync with Noom. I see some of the comments go back several months.  Why has it not been resolved yet?
MrZell
Black Hole
Gear and Gear Fit
We are unable to confirm the compatibility of Samsung Devices when used with Non-Samsung Products. I would recommend reaching out to our Samsung Health team in your area.
user16A14GJkcy
Gear and Gear Fit
Noon only allows syncing steps from other devices, nothing else. This is a noom problem not a samsung one.
SamsungQue
Honored Contributor
Gear and Gear Fit
An Accepted Solution has been marked and provided for this thread. The thread will now be locked for further replies. in hopes to keep the integrity of the thread from steering in a non-technical manner. If you have a separate concern, feel free to post again or send one of our moderators a private message with more details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed to keep our community organized and make it easier for our users to find resolutions and needed content. Remember that if you do make a post, please include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring with your product. Thank you for being part of the community!
user1njGhxibgG
Gear and Gear Fit
I am using Noom and cannot sync my steps with my Active 2 watch and Noom. Why does Samsung have the biggest compatibility problems with other apps and software? It seems by limiting compatibility Samsung hopes to push their own products and apps like Apple. If this happens I will stop buying Samsung products - already the TVs are lacking many apps that they should have.
