Novauser
Cosmic Ray
Treadmill says 0.87 mile....gear fit2 says congratulations you did 1 mile
JUMP TO SOLUTION
So which is right? I tend to believe it's the treadmill...
im connected to note 7 btw
1 SOLUTION
Neutron Star
Re: Treadmill says 0.87 mile....gear fit2 says congratulations you did 1 mile
JUMP TO SOLUTION
Of course Treadmill. The watch is only guessing from number of steps.
Superman on Galaxy S7 SM-G930T, T-Mobile, Baseband:G930TUVY3APIA
To OP: click "✓ Accept as Solution" when you find an answer that works for you.
3 REPLIES 3
Neutron Star
JUMP TO SOLUTION
vbprog
JUMP TO SOLUTION
OK - but my question is: how do you get the gear fit2 to even say what the treadmill distance is? If I start my treadmill execercise on the device it gives me only duration, heart rate and calories. No steps or distance.
Are you not specifically starting a treadmill exercise and just letting the device count regular steps....?
userg4W2NVOq6X
JUMP TO SOLUTION
I know this reply is a bit dated, but I find that If I am carrying my cell phone with a healh app (such as samsung health) linked to the fit2 that between the 2 you will get lot better readings. The Fit2 determines your steps by your arm swings. For instance is you go for a walk in freezing weather and keep your hands in your pocket it will say that you haven't gone anywhere, but your phone will record your steps (different algorithms).
