Uber companion for samsung Gear
(Topic created: 03-03-2021 10:46 AM)
Klbsr
Gear and Gear Fit
I am using a Samsung Galaxy S9+ and a Samsung Galaxy Gear S3. I am having trouble with the Uber companion for Samsung Gear. Eveytime i try to log in it says, "the log in information is incorrect". However, it doesnt redirect so that i can correct the log in information. I am stuck on the "get started" page.
SamsungRei
Gear and Gear Fit
As the troubleshooting we have provided has not been of help, I recommend reaching out to the app developers as Uber/Uber Companion is not a Samsung app. I apologize for the inconvenience.
SamsungJoJo
Gear and Gear Fit
Have you attempted to uninstall and reinstall the app and try logging in again?
Do you experience issues logging in to other apps?
Have you attempted to reach out to the app developers of this specific app to see if they can provide any further assistance?
Klbsr
Gear and Gear Fit
I have tried the clear data & cache method
I have tried uninstall/reinstall
I have even done a full factory reset
Nothing works.
user4NwDub42zn
Gear and Gear Fit
The same is happening to me, i am in Brazil
userYehE86cfzP
Gear and Gear Fit
same here. s10 with watch active 2 LTE. Incorrect login into gear app.
Stephanie Nikki
Black Hole
Gear and Gear Fit
Can I ask which exact Gear app you are attempting to connect to? Its possible the incorrect one could be downloaded. The one you're looking for should be a Yellow/Orange icon labeled Wear and the name is "Galaxy Wearable (Samsung Gear)".
usernDOeXdyj9m
Gear and Gear Fit
@Stephanie Nikki He means the Uber for Gear Companion app as mentioned in the title
SamsungRei
Gear and Gear Fit
