Highlighted
Re: Unable to connect my Gear S3 to Gear app on my phone.
JUMP TO SOLUTION
Just got an update pushed to my phone, updated Galaxy Gear to Galaxy Wear. Paired to my phone running Android P right away, looks to be fixed!
The watch also got a software update, battery enhancements and security updates I believe.
If you do not get an automatic update, try manually updating the gear software on the phone. Happy to be able to use my watch again.
Highlighted
JUMP TO SOLUTION
Apr 12, 2019 - I had this problem today.
To get to the point, I realized no Galaxy apps would recognize / connect to the Wi-Fi network - to accomplish the required update.  I turned Wi-Fi off.  I was then able to update the "Galaxy Wearable" app over the carrier's network....
Highlighted
JUMP TO SOLUTION
I had to reset my watch (lost all my settings) and bypass the initial phone-watch connection (click on the icon at the bottom right (?) and select to use the watch without syncing to a phone.  I then proceeded to connections, connected with Bluetooth, and followed the setup process that way.  The watch was reset and reconnected after powerup.
Highlighted
JUMP TO SOLUTION
I am expieriencing the same issues. I have a Samsung Note 8 phone and it is unable to pair with my Frontier S3 watch. I have conducted all the steps in this forum with no luck. What are my next steps?
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
I had trouble pairing when I first got my Gear s3. After no success last night and Samsung recommending to take it to a service center;  I found a solution this morning.
I reset my network connections and then I was able to pair my Gear S3 Frontier to my Galaxy Note 9.
Highlighted
JUMP TO SOLUTION
Have you tried all of the troubleshooting steps listed in this article? http://www.samsung.com/us/support/troubleshooting/TSG01003238/#reset-your-samsung-smart-watch
