Highlighted
Re: Unable to connect my Gear S3 to Gear app on my phone.
JUMP TO SOLUTION
Can I get your full model code, baseband version, and carrier information?
Highlighted
JUMP TO SOLUTION
I know it is my phone as I connected to my old phone, droid turbo, and it is ok. The gear app just exits after it finds my watch and Android informs me that the app has closed.
I have pixel XL, have beta version 9. I do not think this is the issue as it was working fine, there was no update that broke it.
I have uninstalled gear, gear s and Samsung accessory service without any luck.
I really do not want to do a full reset on my phone. Something is making the app exit when trying to pair.
My watch is tizen 3002, aw cre3,
What is my next move?
Highlighted
JUMP TO SOLUTION
We need the actual model code and baseband information for this device.
Highlighted
JUMP TO SOLUTION
Which, my phone?
Pixel XL model PVT. Idk where baseband is
Highlighted
JUMP TO SOLUTION
Pixel XL, model PVT
Don't know where baseband is, isn't that just for cell phone communication?
Highlighted
JUMP TO SOLUTION
Sorry for the confusing. The following link will show you how to obtain the model code. baseband and carrier. Let us know if they are helpful. link
Highlighted
JUMP TO SOLUTION
here we go
SN: <Hidden>
Model: SM-R760
Tizen: 3.0.0.3
SW: R760XXU2CRE3
I still think there is something with the phone. my Droid Turbo connects, my Pixel XL will not, it finds it and when i try to pair, the app crashes. uninstall resinstall all 3. no change.
Highlighted
Supernova
JUMP TO SOLUTION
@useryEYRwIl8eS: Just to clarify, what troubleshooting steps have you completed on the Gear itself so far?
Highlighted
JUMP TO SOLUTION
Hello Michelle. 1. I have uninstalled and resinstalled all 3 apps, no change. it can find the gear, but when selected to pair, app crashed immediatly on my pixel XL. 2. I pulled out my droid turbo old phone, installed the apps, connected and works. Again, I will stress, i appears to be the phone. i am using android beta 9 but this just started less than a week ago and i have been using the beta for long before that.
Highlighted
Supernova
JUMP TO SOLUTION
@useryEYRwIl8eS: I completely understand. Honestly, if the Gear works properly with your old mobile device, I would recommend reaching out to the manufacturer of your new mobile device.
