Re: Unable to connect my Gear S3 to Gear app on my phone.
JUMP TO SOLUTION
If troubleshooting steps have failed, you may need to talk with the carrier, visit your local Best Buy with a Samsung Experience shop inside, or send the device in for service.
usera7jm4SDQbI
JUMP TO SOLUTION
Im having the same issue, did you get it figured out? Mines was on standalone mode and would drain my battery so i tried to do a factory reset now it wont do anything.....
user9xYLjDwVRL
JUMP TO SOLUTION
**Possible Solution**
*Explanaton*
I was having the same issue. The watch pairs (I get prompted for the PIN number and everyting on both the watch and the phone) but it would not actually connect.
Phone: Samsung Galaxy S6 with latest software updates
Watch: Samsung Gear S3 Classic SM-R770
I tried the following with no initial success:
 -Reset the Watch to factory conditions
-Cleared Cache and Data from Wear App, Gear Plugin App, Samsung Accessories App
-Uninstalled and Reinstalled the Galaxy Wearable App
-Unpaired and re-paired the bluetooth again to try and establish a connection
**Solution**
Went back and uninstalled all three the components individually (Wear, Gear Plugin, Samsung Accessory Service) via Settings -> Apps -> Click each app individually and uninstall
Restared the phone and the watch for good measure.
Reinstalled the Galaxy Wearable (Samsung Gear) App
Started the pairing process again and lo and behold, it worked without a hitch. Hopefully this helps.
userjw1fZPiLfL
JUMP TO SOLUTION
I have tried all other steps listed in this forum, and to no avail. I tried these steps suggested by
user9xYLjDwVRL and worked on the first go. Thank you so much. My situation is a Gear Frontier S3 and a Galaxy Note 9.
user36uZyU5nNE
JUMP TO SOLUTION
Hi their samsung I have the same problem, before I dont have any problem with connection until when I update It it cannot connect to my iphone. you are saying to try this  (Settings>Apps>Gear Manager on your phone, then pressing Storage. The options to clear the cache and data are in there) the New version is that Setting>AppsSetting - But their is no gear Manager... Iam on Tizen version3.0.02 . I tried to delete the bluetooth save pair but still nothing happens.I am using gear S3 frontier
userG01o2KJri7
JUMP TO SOLUTION
Official Android P update is out and this still doesn't work. Wasn't the beta test period for companies to test their software and get it right for launch. Looks like Samsung spent months sitting on their hands. This is ridiculous.
useryEYRwIl8eS
JUMP TO SOLUTION
I agree. I now have a $300 watch without the fitness tracking and text indications. I have the Best Buy warranty, i was thinking of just going back and turning it in as bricked by the manufacturer. Get a Garmin or something. Some other hi end watch to chronicle my pulse and workouts. ha.
userdeTjF4NhPK
JUMP TO SOLUTION
Count me in as well.
Just got my Frontier watch today from Samsung and no way to pair it up or use it Smiley Sad
JUMP TO SOLUTION
@userdeTjF4NhPK; Hey, what type of phone are you attempting to pair the Gear with? If you can provide me with the full model code, baseband, and carrier information; I would be happy to look further into the issue for you.
userfUKGe3lrlT
JUMP TO SOLUTION
My watch connected to my phone for the 1st week but hasn't been able since. Into the 2nd week some joke...
