Unable to unlock me s3 classic
(Topic created: 03-29-2020 06:29 PM)
Link1Walid
Gear and Gear Fit
Vanessa4
Product Expert
Gear and Gear Fit
Hello,
If you are logging into your Samsung account and are still getting that same message then it is possible you'd have to mail in your device to turn off the reactivation lock. I have attached a @samsungmoderator to further assist you with your situation.
Vanessa4
Product Expert
Gear and Gear Fit
Hello,
Link1Walid
Gear and Gear Fit
I took the steps and now I get a message that the watch was closed from another email, which is not correct
