Highlighted
Re: gear fit2 burn
JUMP TO SOLUTION
Model sm-r3600daaxar
Serial no. <hidden>
Highlighted
Re: gear fit2 burn
JUMP TO SOLUTION
Can you send where this device was purchased via private message?
Highlighted
Re: gear fit2 burn
JUMP TO SOLUTION
Hi
I had the same problem - a burn-like injury under the watch and itcy irritation on either side of my wrist where the strap wraps around.  I have established that the burn under the watch itself is caused by the heart rate monitor, and the irritation from the strap is a reaction to the material in the strap.  I replaced the strap with a woven nylon mesh strap that I purchased on the internet, and have had no strap irritation since (over one week now - before it was appearing within 2 days).  I have switched the heart rate monitor off altogether and the burn under the watch has not reappeared for about 5 days now, since I switched the heart rate monitor off.
Highlighted
Re: gear fit2 burn
JUMP TO SOLUTION
My mother is having the exact same problem with the watch I have her as a gift. How did they solve the problem? Hey wrist looks awful everytime she wears it.
Highlighted
Re: gear fit2 burn
JUMP TO SOLUTION
@Mrscmharris Can I have your full model code, serial number, and IMEI number (if LTE) via private message? We would like to look into this further for you.
Highlighted
Re: gear fit2 burn
JUMP TO SOLUTION
Did anyone get a solution to their problem after private messaging the Samsung mods with the model and serial number?
I have an itchy, red, painful rash where the band touches the underside of my wrist.
I'm wondering if the band has nickel or some known irritants in it.
Highlighted
Re: gear fit2 burn
JUMP TO SOLUTION
@peasandcarrots I would be happy to assist you further. Can I please have your full model number and serial number as well as pictures of the symptoms you are experiencing in a private message: http://bit.ly/2JH2rq2
Highlighted
Re: gear fit2 burn
JUMP TO SOLUTION
I too have been burned by this device on two occasions. I am sad because I really like the functions. Would love to post a picture to show the latest burn, but can't on this platform.
Highlighted
Re: gear fit2 burn
JUMP TO SOLUTION
I am very sorry to hear about the burns! I would like to look into this further for you. Please send a private message with the full model code, the serial number or IMEI number of the watch, and your images. Images may be uploaded using a web browser. http://bit.ly/2XERsky
Highlighted
Re: gear fit2 burn
JUMP TO SOLUTION
Hey, just wanted to follow up. Are you still needing further assistance?
